Python Speed: Getting the first part of a string
Mar 24, 2008 · 1 minute read · CommentsPython
If you want to get the first part of a string (in the following example a), you should use the partition method of the string, as it is the fastest way (and it also gives you the delimiter in [1] and the other part of the string in [2]):
In [1]: a = ‘a/b/c/d/e/f/g/h/i/j/k/l/m/n/o/p/q/r/s/t/u/v/w/x/y/z’
In [2]: timeit a.partition(‘/’)[0] 1000000 loops, best of 3: 362 ns per loop
In [3]: timeit a[:a.find(‘/’)] 1000000 loops, best of 3: 443 ns per loop
In [4]: timeit a.split(‘/’, 1)[0] 1000000 loops, best of 3: 697 ns per loop
In [5]: timeit a.split(‘/’)[0] 1000000 loops, best of 3: 1.45 µs per loop
These tests were made with IPython 0.8.1 (Python 2.5.1 (r251:54863, Oct 5 2007, 13:50:07) ) on an Ubuntu 64 bit system.
